A Different Chart of Accounts
When I create a new company, Navsision pulls in the chart of accounts currently being used. I need to set-up a new company that will not consolidate and will need to have a different chart of accounts. Is this possible? Thanks
When you create the new company you can create a whole new chart of accounts, just don’t copy the G/L Account Table if you are using the copy function front the Setup Checklist. Cheers Peter
Either Peter has the correct answer or it could be that your G/L Account table has had the DataPerCompany property changed so as to behave exactly like you described. If the latter is true, there is not much you can do without a serious redesign of your implementation.
