Dear All,
I need a code to display a message when job % is up to certain % and where to place the code. Your assistance will be very much appreciated.
Regard
Gbenga
Dear All,
Regard
Gbenga
Where you need this message? while doing what?
I think this code might be helpful
class className
display edtName methodname()
tablename tablename
select name from tablename
where tablename.reqfield == this.reqfield;
return tablename.name;
Hey is this NAV related or AX?
Please make sure to post questions/Answers in right forum…
Thanks Mohana,
I need these code when opening the job card. Its nav.
Gbenga
Thanks Jasmine,
I want the code to display the message when opening the job card and its Nav related.
regards
Gbenga
few quick questions?
are you a developer or end user?
If end user, please don’t play with Database…
based on which field you want to calculate?
Hi mohana,
Am a developer it’s base on cost completion %
thanks
I didnt find cost completion % field in Job table.
but still
Write the below code in Form - OnAfterGetRecord() of Job Card (Form 88)
IF “cost completion %” = X Then
Message(‘Cost Completion % is %1’,X);
Dear Mohana,
Thanks, but the cost completion % is on the job taskline table and not on the job table. Sorry for not detailing down to that extent . I want a situation when the job card WIP is calculated it reads through the taskline if there is any posting on the taskline that cost completion % is above certain level. These message should come up when the WIP is calculated. I hope have been able to pass the message accross.
Regards
gbenga
I have no idea of this functionality…
“Cost Completion %” is calculating in 5 functions
CalcWIPAmount1 to CalcWIPAmount5
You need to write a function and pass “Cost Completion %” paramer from all 5 functions
and write
IF costcompletion%parameter = X Then
