If YOU would have to choose between Navision DB-server and Microsoft’s SQL. What would be pro-s and contras of each of them? Looking at the price list of granules i notice that Microsoft is trying to push MSSQL server thru. They are gonna loose Navi DMBS?
With SQL Server, u can perform more restrictions on user permissions plus the DB Size is unlimited in SQL Server. Cheers
But the performance is usually not as good as on navision db server…
Performance wise – navision DB is definitely fast. Size wise — Sql Server DB is preferred You must Analyze the client application , if the database is going to increase tremedously in future, One should choose sql server.
You might also consider SQL if You have a lot of integration to do. If not so heavy integration and moderate number of users and data growth I recommend C/SIDE. Much more performance for the money spent and tremendously easy to maintain.
Hi, What about the support for Navision db in the near future. IS MBS going to support Navision db or promote MS Sql Server Regards Jyothi Mohan
Both! MS is going to support native in the future (they are not allowed to force SQL to existing customers), but will promote SQL. You can see it already now: session killer for example is only available on SQL…
One more advantage, with SQL option u can put multiple DBs, All with multiple Companies like the native Navision DB.
