401 Unauthorized error: ReadMultiple method of web service
I have created a simple Page web service on the Fixed Asset table as I want to read the Fixed Assets in NAV in another web application. I have created and published the web service in NAV and can access it from a browser. I have added a web reference to my web application (which uses forms-based authentication) and I have the following code to read and list the Fixed Assets:
Dim AssetWS As New NavFixedAsset.FixedAsset_Service
AssetWS.UseDefaultCredentials = False
AssetWS.Credentials = New Net.NetworkCredentials(“sa”,“password”)
Dim dt As DataTable = New DataTable
Dim dr As DataRow
dt.Columns.Add(New DataColumn(“No”, Type.GetType(“String”)))
dt.Columns.Add(New DataColumn(“AssetReg”, Type.GetType(“String”)))
dt.Columns.Add(New DataColumn(“Description”, Type.GetType(“String”)))
dt.Columns.Add(New DataColumn(“FALocationCode”, Type.GetType(“String”)))
dt.Columns.Add(New DataColumn(“SerialNo”, Type.GetType(“String”)))
For Each FixedAsset As NAVFixedAsset.FixedAsset In FixedAssets
dr = dt.NewRow
dr(0) = FixedAsset.No
dr(1) = FixedAsset.Asset_Reg
dr(2) = FixedAsset.Description
dr(3) = FixedAsset.FA_Location_Code
dr(4) = FixedAsset.Serial_No
dt.Rows.Add(dr)
Next
Dim dv As DataView = New DataView(dt)
DataList.DataSource = dv
DataList.DataBind
The sa username is created in NAV as a database user, and the credentials being passed are correct.
The error is “The request failed with HTTP status 401: Unauthorized.” and it seems to be thrown when the ReadMultiple method is called. I have tried with UseDefaultCredentials = True but then the machine name is passed (eg. DOMAIN\COMPUTER$) which is not a valid user in the NAV database.
Can anyone advise how this should work please?
Webservice/service tier only work with windows authentication.
hi Rashed Amini
we can also send username and password manually this is as per my info .
what is your opinion?
yes you can send them, but they have to be windows users. AssetWS.Credentials = New Net.NetworkCredentials(“sa”,“password”)
