Hello Solved thank you all. Deeps
you should use COM or COM+ interface.(via Axapta COM Connector)
Hi Deepak, Do you want to implement this integration within Axapta or outside Axapta? If within, have you had a look at SysMailer class yet? Also you might want to take a look at Tutorial_COMAgent form. If from external application, then you might want to check the examples that are available in Developers Guide. Alternatively if you can let me know your requirement, I might be able to assist you. Regards, Harish Mohanbabu
