hi
1- is there way to delete customer (with transactions) ???
2- how to make system not accept new credit limit – if new credit limit less than balance ???
3- in Reports under criteria how to make pop-up menu classic
classic mean not accept manual entry (only select from menu)
and stop and (,)
from to (…) Feature from reports
and sorry for this Question
I know some question not logical
but already someone ask me about this?
and i can’t not reply
thanks alot
for first point
i can filterd customer
for second one (i can stop change?? )give me path of it please in axapta 3
third one this need developer
thanks again
You can filter the customer? Makes no sense in a reply.
What path for the second one? It is a modification if you want to achieve it as I said it is not standard functionality.
ok thanks
and sorry for this questions
i know all is stansard
But this customer not accept explain for this issue
Then you need to sit with them, map out the requirements, give them an estimate and if they accept the costs write and test the modification for them.
Does not accept the dialogue with him
ok thanks and sorry for inconvenience
So they will not let you talk to them but want you to do the work without explaining why they want it? Quote them 100 days on the basis of the unknown as they are unwilling to discuss the requirements in full and see if dialogue starts!
