3.60 ODBC driver
I need a 3.60 ODBC driver for my Nav 3.60. The program disk contains my Navision Software only, no odbc driver. Where can I get a 3.60 ODBC driver? Thank you.
It should be within the 3.60 cd that you were given by Microsoft… …are you sure that is not part of the cd…? If not, then you should probably contact you MBS branch, in order for them to send it to you…
