3.10a proprietary to SQL
Hi all, IM trying to restore a 3.10 database to sql2000, I’ve run into lots of errors - mostly that SQL doesn’t like the 4 digit year that navision puts in - fixed those and then backup - and restore again. Now I’ve run into a “Numeric value out of range State ID: 22003” Any idea where I can look, Perhaps Im going about this conversion all wrong, is there a tool/codeunit that one can use in orfer to prepare a 3.10 db before restoring into SQL ? Thanks Faizel
Sounds interesting - I presume that you did a .fbk file from the native database, and are trying to restore this with a Navision client connected to the Server? On annother note, I would strongly encurrage you, to upgrade the executebles to 3.70A!
