3.10.A: TableRelation Lookup not working
In version 3.10.A I cannot make the TableRelation Lookup not working from Textbox controls on Reports or Dataports in the Request Options. [:(!] I’ve not experienced this in other objects or anywhere else.
I cannot either make it not work since it works :slight_smile: If You create a report and on the Request Form put a textbox with the source expression “Customer No.” (a global variable) and a relation to the table Customer it should work. It does for me in SE3.10A. Have You done anything with th LookupFormID Property on the tabel to which You have You relation? /Lars
