Have anybody tried export/import of objects from 3.01 to 2.01 ? I have problem … big problem. After import/export fin.exe crashes on object compile [:(!]. Not Multilanguage associted… I think so.
You can not “downgrade” object just by importing them. You have to do it manualy. Hope you can copy field from 3.01 to 2.01. Maybe you can delete all non 3.01 properties from a text export of your object… In that case, Good luck!
Actually I found that I can’t copy/paste fields (in tables) with code and functions. Anything else works fine. Same problem is about forms, I’m not sure about reports (didn’t get so far).
