25 qty can not picked because only -65 qty is/are available from the inventory
Dear All,
can anybody tell why this is error is comming while posting the po packing slip
error is: 25 qty can not picked because only -65 qty is/are available from the inventory
Regards
Siddu
hi siddu,
This error comes whenever u try to consume negative inventory (means physical inventory is already in negative).
If you want to do further, u can check physical negative inventory checkbox, available in inventory module–>setup–>inventory–>inventory model groups–>under setup tab u have this option. u can chek this and verify whether u get that error again.
regards,
ramya
hi ramya,
thanks for ur replay…
yes you are correct,already negative stock is there which is i am traing to post the Purchase GRN but we are not consuming(using the mstock) that negative stock, we are traing to increase the stock thru posting the po grn so it should throw error correct?
regards
siddu
If it is not a single line order set teh receipt quantity in teh recieve now and just process the line.
Hi Adam,
sorry,not understanding what you are telling,pls can you tell clearly…
Regards
Siddu
Process the line as you would a partial receipt - or do you not know how to do this as standard functionality?
Dears,
I have the same error “5.00 cannot be picked because only -96.00 is/are available from the inventory”
I’m working in ax for retail and this error appears when I post statement and the "Physical negative inventory " is checked in warehouse “retail” fast tab
any ideas because I didn’t understand the above solutions
