I am using NAV 2013 R2 with Serenic. Budgets. When I run a calculation on the budget the RTC Client crashes. How can I find out this error? I tried to debug but it closes when my RTC Client closes. I looked in event viewer and the only thing that looks like an error is below:
Application: Microsoft.Dynamics.Nav.Client.exe
Framework Version: v4.0.30319
Description: The application requested process termination through System.Environment.FailFast(string message).
Message: RecordImplementation internal error: performed rename instead of modify.
Stack:
at System.Environment.FailFast(System.String)
at Microsoft.Dynamics.Nav.Client.WinClient.StartWinFormsClient.HandleGeneralException(System.Exception)
at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.DoRethrowWithCatchException(System.Exception, Boolean)
at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.DoHandleThreadException(System.Exception, Boolean)
at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.WinFormsDispatcherUnhandledException(System.Object, Microsoft.Dynamics.Framework.UI.DispatcherUnhandledExceptionEventArgs)
at Microsoft.Dynamics.Framework.UI.WinForms.WinFormsDispatcher.HandleDispatcherException(System.Object, System.Exception)
at Microsoft.Dynamics.Framework.UI.WinForms.WinFormsDispatcher.OnThreadException(System.Object, System.Threading.ThreadExceptionEventArgs)
at System.Windows.Forms.Application+ThreadContext.OnThreadException(System.Exception)
at System.Windows.Forms.Control.WndProcException(System.Exception)
at System.Windows.Forms.Control+ControlNativeWindow.OnThreadException(System.Exception)
at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
at Microsoft.Dynamics.Nav.Client.WinClient.NavWinFormsClientSession.RunMessagePump()
at Microsoft.Dynamics.Nav.Client.WinClient.NavWinFormsClientSession.RunCore()
at Microsoft.Dynamics.Framework.UI.Windows.ClientSessionBase.Run()
at Microsoft.Dynamics.Nav.Client.WinClient.NavClientErrorHandler.ExecuteAndCatchExceptions(System.Func`1)
at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.DoExecute(System.Func`1)
at Microsoft.Dynamics.Nav.Client.WinClient.StartWinFormsClient.RunCore()
at Microsoft.Dynamics.Nav.Client.WinClient.StartWinFormsClient.Run(Boolean)
at Microsoft.Dynamics.Nav.Client.WinClient.StartWinFormsClient.RunAndDispose()
at Microsoft.Dynamics.Nav.Client.Program.ExecuteNormally(System.Func`1)
at Microsoft.Dynamics.Nav.Client.Program.Main(System.String[])
