Dear all Can you tell how to slove the problem Vendor ageing is not coming if other then 9999 line in the repot
Hi Sridhar, You have to go to the report and change the array dimension on the Global variable properties to 99999 and also in the code you have to change the array length to 5. This would allow to print the report more than 9999 lines. Thanks Best regards Suresh. New York.
Hi Suresh Thanku very much. it is working fine now.
